rayc
retroreprobate
Whgatever gets you charged up & ready to go lieutenant!
Old thread, but anyway:(1) They lose charge in storage. Some say that you should figure 1% per day. My experience is that the 9V batteries lose charge in storage at a faster rate.
I saw one at the local GC this past weekend.
Makes sense, since a 9V battery is a stack of 6 1.5V cells; if each loses 1% per day, the battery would lose 6% per day.
Maybe for recording where every tiny bit of noise is objectionable ...... but the difference between the two noise-wise is pretty small. The only time I can really hear it is if the club is perfectly quiet which is rarely the case.I can't imagine that if you A/B'ed the difference between a chain of pedals with batteries and then the same chain with an AC adapter that the AC adapter wouldn't be noisier.
I've had 3 different AC adapters, and all of them were noisier than using batteries.
You're right.Um, no. Six times 1% of 1.5 is still only 1% of 9. I have no clue about rechargeable battery life or losses, but your math is not correct.
digital effects pedals rapidly drain batteries. while I could use ac adaptors they tend to use up 2-3 outlet spaces. I've seen many AA NiMH rechargeables but thusfar few for 9V. Do they exist? What mAh rating is required for use with guitar effect (like with Digitech MultiChorus XMC)?
thanks
sathyan
