M
mattkw80
All the software would have to do - is have a master program, with several little nodes running in each track you want to see.
So you stick node1 on the bass, node2 on the guitar, node3 of etc. etc.
And then.... the master program will show the frequency graph drawn for each node, in different colors.
You would very clearly be able to see where each intrument sit in the spectrum. I've talked to a friend is who is a very advanced programmer - and he's says he could do it, if it looks like a worth while project.
I know I need to develop my ears -- but I've already been doing that for 5 years or so --- If I can get some technology to give me an edge, I'm going to. I understand paying your dues - and I do believe in experience as the best teacher -- but I need to speed things up here -- I've got bands who want to record now.
I'm not going to buy Har-bal.... but I think there is value in a multi-instrument frequency analyzer.
. The problem/question here becomes, how do you know whether what you are seeing is good or bad? Should that peak be there at (x)Hz or is that a bad one? If both are peaking there, is that right or wrong (maybe it actually sounds good for them to do that)? How can I tell by sight if that peak is too much or too little? Is the problem really that minor-looking peak a couple of yard lines to the right instead of that big obvious one on the left? Hint: it often is. How is one to tell by looking? The same goes for all the troughs, BTW, not just the peaks.
