mamm7215
Member
So I downloaded some test tones from analogrules.com. They had a good small set of 30 sec tones of 1k, 10k, 15k, 100hz, and 50hz in one wav file I loaded into Sonar. I set the levels so that it would read 0dbvu on my TSR-8 (led's). Now on my system I had to set the output on Sonar at -15.5dbfs to get 0dbvu on the deck. That mean anything? Also, you need to bear in mind that the deck has NOT been demagnetized yet. My demag hasn't arrived so this is a preliminary "general" test. I recorded the tones to tape. All meters read 0dbvu on input/record. No wavering, rock solid. On playback, this is what I got:
1k Track 1 dropped about 2db (flickers between -1 to -3db) Tracks 2-8 solid at 0. Track 8 flickers above 0 1 db late in the tone
10k Track 1 goes to -5db, track 2 to -3, tracks 3,4,5,7 solid at 0, track 6 -1 and track 8 +1
15k Track 1 flickers between -5 to -7, track 2 at -3, tracks 3-7 at -1, track 8 at 0
100hz All tracks steady at +1
50hz All tracks steady at 0 except 2 flickers between 0 and +1, track 8 at +1, and 4 and 5 bump to +1 towards the end of the tone, but initially at 0.
I'll redo this test after I get it demagnetized, but any opinions? Seems track 1 and 2 take the biggest HF hit on playback. Could it also be the tape? It's not new. Quantegy 456, came with the deck.
Thanks.
Thanks.
