Seeker of Rock
Seeker-Lou ‘32
So the IRS owes me a couple of hundred dollars it looks like. If I can get $200 of it from the wife, what do you think about ceiling absorption vs. floor absorption? By meticulously reading and asking questions here, my tracking/mixing room (room-within-a-room, treated inside with Auralex and Realtraps minitraps in the four corners halfway up from the floor, pitched ceiling of reflective wood, etc. from here, Ethan Winer reading and John Sayers' site) is pretty complete, but I'm wondering if I can't take just an inkling of the "live" sound from it. It sounds very controlled, even with the acoustic drum kit I have in there now, but after hearing the PCM90 I bought I'm thinking I may want to be a hair less "live" for a hair more "dampened".
Since the floor is painted concrete (for reflection I was advised back when) but the pitched ceiling is a wood surface plywood (on top of "Sound Deadening Board") so it is reflective as well, I wonder whether I should put some clouds on the ceiling spaced along the crotch of the top ceiling pitch(at least over the mix position by standards), or maybe go for broke and put carpet on the floor, which I fear may take away too much of the little bit of "live" left in there. Any suggestions on what you may do in the same situation?
Edit: Oh yeah, the treatment pattern and room size is this: 12'x13.5' interior space, 4x6" auralex 2" in front of the mixing position, approximately 2.5' from the wall; 2" Auralex 'Metro' stripes floor to beginning of ceiling angle for pitch, 2' wide and every 2' space down both side walls(spaced it so two of these "strips" falls to either side of the mixing position for first? reflections); 4" pyramid foam on back wall, approx. 65% coverage; Realtraps Minitraps in four corners, halfway up from floor to ceiling. No clouds yet in the pitched ceiling, and nothing on the floor but reflection.
