T
tubbabubba22
if i close mic kick, snare, high hat, and each tom and then my overhaeds are in an xy pair right above the set am i going to be ok with phase problems? I was also wondering that just because you keep to the 3:1 rule, will you have to manually make all of the compressions lined up and all of the rarefractions lined up on each of the drum tracks? Sorry if this is confusing but say i record all those mics at the same time. even tho they may not be out of phase right away, am i going to have to go into my DAW and manually line up all the positive bursts of air (out of the speaker) and all of the negative bursts so that the cone moves at the same time? If just mic each instrument while applying the 3:1 rule, i shouldnt have to worry about anything else right? I shouldnt have any issues right? Some help would be much appreciated. I am just trying to make sure. Thanks alot guys.
