A
ahrenba
Hey guys,
I have a couple questions about preamps. I have numbered the questions, so if possible, please number your responses. Thanks!!
1. Is an effects processor (such as the Line6 POD) considered a preamp? I realize that it "tone-shapes" the signal to match cabs from different eras, but is it technically a preamp (boosts signal)?
2. Look at this Product:
http://www.musiciansfriend.com/product/ART-Tube-MP-Studio-Mic-Preamp?sku=180581
It says: "High impedance instrument input bypasses the mic preamp circuitry for a shorter signal path. " Since this means that the instrument input bypasses the preamp, what is the use for plugging it in, in the first place?
3. In conjunction with the question above, do preamps ONLY boost signals from XLR inputs, or can they boost signals from 1/4" inputs also? The reason I ask is because the quote above makes it seem like the instrument signal should be bypassed. Maybe someone could explain this.
4. Do instrument outputs (such as from a guitar) need to be preampped?
5. DI Boxes.....Look here: http://www.musiciansfriend.com/product/ART-Tube-MP-Studio-V3-Mic-Preamp?sku=180610
"Also can serve as an exceptional direct box for impedance matching or simply improving the sound of any instrument plugged into it."
This is listed as a preamp...what makes it a DI Box, and what is the benefit of a DI box other than it converts a 1/4" input to an XLR output (balanced)? Does it change the tone like a preamp would? Was does it bypass the mic preamp? Is it still going to be preampped?
6. Is an active (powered) DI box considered a preamp? If so, why does the info above say that the line input bypasses the preamp?
7. "A passthrough connector is a second output, sometimes simply connected to the input connector, that delivers the input signal unchanged, to allow the DI unit to be inserted into a signal path without interrupting it. This is essential in many applications." Why would you want to use a passthrough, since it outputs exactly the same signal as you inputted? Wouldn't this render the device useless since it just bypasses the signal?
Thanks!
Thanks!
