Farview
There are only two MIC preamps. The rest are line amps.Ok, I am back with another quick question.
Let's use the Lexicon Omega as a reference:
http://www.musiciansfriend.com/product/Lexicon-Omega-Desktop-Recording-Studio?sku=245505
Manuals are here: http://www.lexiconpro.com/ProductDownloads.aspx?ProductID=6&Type=4
This has two preamps (one on each mic input). It also has 4 line inputs and one instrument input.
Now, there are "gain" knobs for both the mic inputs and all the line/instrument input(s).
This is where my questions lies. Doesn't "gain" mean the signal is being boosted? If so, how can there be a "gain" knob on the line/instrument inputs if they do not have preamps? What are they actually doing? Thanks!
A line signal may, or may not, need to be boosted. There are line preamps in there that do that. They will not provide the same amount of gain as a mic preamp. In fact, the line inputs on a 'mic' preamp will generally either bypass one of the amplification stages or will go through a 20 db pad before going through the preamp.
Not all preamps are mic preamps and not all amplifiers are 'preamps'.
You are either getting stuck on the terminology, or you think someone is trying to put one over on you.
It really isn't this complicated.
Any piece of audio equipment will:
1.Have an input that is designed with the proper impedence, level, connector, etc... to take the signal it was meant to take.
2.Then through preamps, transformers, opamps, rectifiers, etc... changes the signal into what it needs to in order to perform it's function.
3.It performs it's function.
4.Through preamps, transformers, opamps, rectifiers, etc... changes the signal into what it needs to in order to output it in the expected manor.
That's it. It's really that simple.
In the case of these all-in-one audio interfaces, the inputs are the proper impedance to accept the signals that they are meant to accept. The signal then is amped, unbalanced, attenuated, buffered, etc... whatever needs to be done to match the signal to what the converters need to recieve. After the converters convert the signal to digital, it is then converted into whatever protocol firewire needs to function. Then, once in the computer, it turns into the digital stream the DAW uses.
I'm not sure what you are getting at with all this.
If there is a gain knob, there is an amplifier somewhere. Even if there isn't a gain knob, there might be an amplifier.
