S
Sedit
Thanks for the files, i will try it later!
How did you mic the bass drum and with what mic?
It's one guitar track. Doing what you propose would cause phasing issues. I'm not sure what you mean by "get the stereo field". I used several different reverbs on all the tracks - different amounts of each one depending on the track. (edit - five reverbs total)
You have a weird thing going on with the bass - I don't know how to describe it, but it "flares" big time on certain notes. Maybe it's on purpose, I don't know.
On a side note - I kept the bass kind of "round" a la Santana, since one of the bass riffs in this song is "borrowed" from a Santana song.![]()
Way badass song - is this your band Nick?
Now, if I get some time I will automate the guitar, it gets a little to overdone - it's supposed to be over-the-top, but maybe not that over the top.....
I did this in about an hour, its kind of an experimental mix. I, too, was referencing RHCP . . . really just the drums, though.
http://www.lightningmp3.com/live/file.php?fid=10839
A few thoughts:
- This is a headphone mix. Sorry, the 1yr old is sleeeeeeping.
- Love the snare! The bottom mic captured some crispness that I dig.
- Bass and kick were tough, but I like how the bass sits really LOW . . . ha ha! The kick is buried, though.
- I ran the drums (always wanted to do this) as an fx send to Guitar Rig 2. Theres a drum preset I've wanted to try, and you can really feel it around 4:00. There's a weird tapping throughout the song (delays) that add a certain something that I couldn't let go of. It kind of adds a bit of the ambiance that the guitar brings later, that digital reverberation. Because of this, I didn't do any effects to the guitar except EQ and compression. But I do wish I got to doubling it . .. darn!
- With the drum effect, I got the cymbals to ring f-o-r-e-v-e-r. They have a great swell just after the attack.
Nick, I'll post a mix later today. The only tracks I thought were problematic were the the kick which was pretty anemic and the bass that has the "tizz" that you already pointed out. The rest of the drum tracks were pretty good.
One from me
takes about 10min till its on
Dirk
Here ya go Nick. Hope it's up to snuff.
http://www.nowhereradio.com/artists/?aid=1331/singles.shtml
By stereo field I mean the guitar is in stereo and its pretty wide.
I'm not sure how you could manage that from stereo reverb, I'm very impressed if you did manage it from reverb alone.
Please can you tell me what reverb you used and what settings you used please?
I'm eager to find out.
Cheers,
Eck
Just reverb. I'm curious as to what you think I did. It's pretty easy to hear the verbs, as the guitar track is soaked in all 5. It's the only track with all 5 on it. It's a very unnatural room that I created with the layered verbs - I was going for a pulsating "liquid" kind of room - kind of like an acid trip, where the room pulses and breathes and every sense is amplified.
The verbs I used are a plate, a med hall, a large hall, a tight slapback, and a loose ping ponging slapback.
I'll share a little verb trick I like to use, that I didn't use here. I like to take "backing" tracks - they can be back vox, whispers, insruments, or whatever. I'll send them to a plate on an aux but pre fader, then turn the fader all the way down. Makes a huge stereo ghosting effect without any presence to it at all. Real cool trick.
Reverb is the toughest thing to get a handle on IMHO. I am just starting to understand how to get it to do what I want........
edit - Oh, and listen to Eulogy by Tool - I got new monitors this week, and was listening to the beginning of that before mixing this track.
What I did was duplicate the track and nudge 1 of them slightly and hard pan them, thats what I thought you had done at first.
Yeah it can cause phase cancellation when in mono, but it seems fine in stereo.
Listen to the guitar in your V2 vs. my V2. It sounds like the guitar is coming from the sides, not the middle. Mine sounds like it's coming from the middle because it is coming from the middle. Also, there is phasing even in stereo in your guitar track. It has that kinda "hollow" sound that happens when you do what you did. That's basically how phasers work, they just slide the track forward and back so the woosh isn't constant.
The real trick is getting reverb to not sound like reverb.............![]()
