G
Guitardude324
Hey, not sure which forum to post this in, move or delete if this is the wrong place!
I had an M-Audio Project Mix until a few days ago. When recording direct bass, snare drum, and even overheads, the inputs would clip even though I had the gain set as low as possible. I really hated this, and didn't want to buy separate PADs, so I no longer have this unit. (Sold for other reasons as well)
I'm very interested in the Presonus Firestudio/Digimax combo, and am about to pull the trigger, but I just was to check and ask if I will have the same problem with this unit, or are the inputs not as hot as the project mix?
Is this a common problem I was having? Would I need to have either a unit with built in PAD or a separate PAD to solve this issue?
Thank you very much!
And maybe a follow up question. If this will also be an issue with the Presonus gear, what rated Pad would be appropriate? Would a few 20dB pad be adequate most likely, or would it be a better idea to get some 10dB or 30 or 40dB ones as well? I record mainly live rock bands in the bar scene.
