N
nemix
(If anyone would be kind enough to take the periods outa my urls and post the pictures it would be great I can't post other urls yet
)I have came to the conclusion that I will not be able to have a vocal booth and after some reading, I'm not sure if I'd even need one....
My plan was to treat my room so I could use it for both monitoring the music I make and recording in it if this is possible. I used google sketchup to give you guys an idea of how my room is put together (my bed will have to stay btw) The two walls have a large window and blinds on them which i planned to cover with pull down curtains that had velcro (sp?) attached to them, I was then going to hang my foam to that.
If you want any other measurements let me know, would the bed be that bad to keep in here?
)I have came to the conclusion that I will not be able to have a vocal booth and after some reading, I'm not sure if I'd even need one.... My plan was to treat my room so I could use it for both monitoring the music I make and recording in it if this is possible. I used google sketchup to give you guys an idea of how my room is put together (my bed will have to stay btw) The two walls have a large window and blinds on them which i planned to cover with pull down curtains that had velcro (sp?) attached to them, I was then going to hang my foam to that.
