Where are you going to put this thing?
Right here! This is the back wall of the studio, with my rack (currently in a state of disarray, still working on post-construction wiring) (I have an old thread in Studio Building where I have rack construction pics).
Basically, this was a built-in entertainment center/wet bar in what became my studio. The rack takes up the TV portion; in the cabinets below I have much of my inventory (well, the accessories, packaging supplies, etc.) stored. I also replaced an icemaker with a bigass sub
One the right wall you will see there is an HVAC unit behind. My clever idea is to tap a vent in lieu of a blower. I expect it will work OK, if I can get regulation of pressure right (and I keep the AC/heat off when the organ is on!) Behind the cabinets is a utility closet, so I can route blower lines and wiring there quite easily.
The printer on the right shelf will have to stay, so that gives me 32" height on the right, 48" on the center left, and 16" on the far left, above the sink. Also, in the top cubby on the right of the rack, I'd like to have hopefully seven or more of brass clarion/trumpet pipes sticking out. At least enough for a fanfare
I will build a rackmount MIDI controller with 128 or 192 outputs; these will control a valve under each pipe. That means a whole lotta wires into the rack; right now I just have 12 pair for mics and headphones! There will actually have to be four windchests; one for each shelf, so that makes for a good amount of vent work to be done.
There will be a MIDI jack in the little patch panel (above the speaker) to connect a controller. Of course it will also be routed through the computer, so I can record the MIDI performance in individual parts (since I only have one 'manual' and no talent!) and then listen to playback through the organ of all the parts together.
Or I can just scan in some Bach, and kick back
