Llarion
urobolus.com said:All 3 of my drives are Seagate SATAII's. I run an 80gb for the OS and software, 350gb for samples like East West Quantum Leap products, and 80gb for personal project files for Sonar. Runs much better than keeping it all on one hard drive.
Something semi hard drive related that I've been wondering is disabling the paging file in windows. I used to do this because a lot of tech nerds said it makes your computer faster as it makes the computer use your memory instead of using a certain amount of the hard drive as RAM. But a lot of music PC tweaking websites say you should enable it at 1.5x-2x your physical RAM. I haven't done a close side-by-side comparison, but it seems disabling the paging file would be more efficient.
Just some other thoughts...
You don't want to DISABLE the paging file, but you do want to limit its size and keep it a FIXED size. If you have a TON of RAM (I have 4GB) you can run a small one (I run a fixed 256MB pagefile). Have the pagefile on the fastest disk that is not your system disk.
There is a registry tweak you can do that prevents the OS kernel from ever paging, and you should DEFINITELY do this. Keep that lil puppy in RAM, and your disk subsystem will love you for it. Download Tune Up Utilities 2007, fre 30-day fully functional timebomb trial, the tweak is in there. HUGE difference if you have a lot of RAM.
I have someone helping me, because I am a noob PC 'r.
about 2 years ago i only used 1x 500 gb HD partitioned in to 2 drives i had all my projects on 1 partition and the os and programs on the other. I never used to back up ether
