Zoom rt323 Drum Machine
  • Thread starter Thread starter guitarjesus
G
guitarjesus
Had a question.
Every time I lay a drum and bass track, I can never get it to loop smoothly if you know what I mean. The ending and the begginning aren't smooth.
What is the trick on doing this?
Sounds like a timing issue. Are you using preset rhythms or user created?
Are you using the click track or doing any quantizing? Usually if a loop jumps a bit it means the timing isn't right on. It's most noticeable on the high hat or any other constant part.
I fingered it out.
I just changed the beats per measure, and it worked.
Great machine.
I lay down the drum beat first, then the bass. The bass is easy when you have the drum beat all ready layed. If I need a faster beat I increase the tempo.
Your the only one that tried to help be out. Thanks.
