Eddie N
10 Inch Member
ok..heres the set up..
abit bp6 mobo with dual 533 celerons
128 megs ram
10 gig maxtor hard drive (not udma 66)
agp video
pci audio
primary ide port :
master cd-rw , slave cd rom
secondary ide port :
empty , unless you count the lil port that you use for the floppy drive..
primary udma/66 ide port:
maxtor 10 gig hard drive
problem is , with that set up , i get a "hard disk not found or properly powered up" message after it boots from the last install dick (4).. when i connect the hard drive to the primary ide port as master and the cd-rom as slave , it works fine...but i heard that you shouldnt have a hard drive and cd-rom on the same ide port.. i cant seem to get the udma/66 ide ports functioning properly.. anyone have any ideas ?
the ide cables the mobo came with are screwy.. three in total..one has 2 floppy sized connectors , and one has 2 hard drive/cd-rom type connects.. the last one is for the udma/66 .. shouldnt the idea connection be floppy and hard drive on the primary ide port , and the cd-r and cd-rom on the secondary ? i dunno..im new at this..
also , i couldnt get windows 98 to install from the bootdisk..weird..i just suck..
- eddie -
128 megs ram
agp video
pci audio
primary ide port :
- eddie -
