Normalizing is different. It has no compression involved. You merely raise the volume so that the loudest peak reaches 0dB (if normalized to 100%).TelePaul said:Is maximising similar to normalizing so?
LogicDeLuxe said:Normalizing is different. It has no compression involved. You merely raise the volume so that the loudest peak reaches 0dB (if normalized to 100%).
That peak usually sticks out without real value to the music, therefor a reasonable amount if limiting doesn't hurt. To find out what amount is reasonable, you best use a limiter without boosting the volume at the same time and compare it to the imput. If you're happy with it, you can normalize it. The combination of compressing and/or limiting and raising the volume (normalizing) is called maximizing.
Somewhere in between the comments, he wrote what compressors he used, though it doesn't really matter as you can damage your sound with any compressor.
A master limiter is just a limiter you use after mixing down, and of course, it does the limiting. What did you expect?TelePaul said:Is limiting completely different to using a Master Limter?
Obviously, the intention of his demo is not finding the best compressor, but to question the excessive use of it. Well, with using a really bad compressor applying really unsuitable parameters, the video might be slightly biased, though it is not far from comon practice, unfortunately. Also Youtube is not great quality anyway, so he had to find something really apparent. He did, and he surely made a point.bblackwood said:It's a decent vid, but it sounds like the guy used the worst limiter he could find to make the loud version...
TelePaul said:Oh okay great, thanks. Is limiting completely different to using a Master Limter?
By going to the New Rep Point Thread for startersRobert D said:I'm just curious, how do you get 14,000 rep points and not know the difference between a regular peak limiter and a mastering limiter?
If he wants to make a point, he should at least be fair about it. By using such a crappy approach to achieving the 'loud' version, he comes off as an amateur at best and deceptive at worst...LogicDeLuxe said:Obviously, the intention of his demo is not finding the best compressor, but to question the excessive use of it.
