R
Robert D
Wow Glen, time to call a publisher.
You know any???Robert D said:Wow Glen, time to call a publisher.![]()
. I used all my time (thanks Jay!
) typing and didn't take time to spellcheck very well... While I don't disagree with you that going beyond 20kHz (or 40kHz sampling rate) on recording/reproductive systems is usually an overkill, there are other technical reasons for doing so.SouthSIDE Glen[B said:Y20k?[/B]
Now you mention that 20kHz may not be a fair upper limit. I addressed this in a earlier post. Even those that fall on the side of thinking that there is an elusive "air" to be obtained by resolving some frequencies above 20kHz or so - and that is an honest debate which not even the "experts" agree upon - don't believe that frequencies anything above 30khz are useful. That would mean a sample rate of 66.15kHz or so. The fact is, that even for those golden ears and audiophiliacs, 88.2kHz is overkill already by a good 22kHz. A 96kHz rate is just piling on, and 192kHz is ridiculously obscene.
So perhaps, PERHAPS, one might argue that the next steps up from 44.1kHz - namely 48kHz and 88.2kHz might have some worthiness in audiophile-class recordings. But that is certainly debatable - the experts debate it all the time - and certianly not solidly backed up by expirimental data from actual controlled listening tests. Test after test has yield, at best, conflicting or inconclusive results. It is also not backed up when looking at the limitations of the rest of the signal chain from microphone to loudspeaker, which simply are not designed to give a rat's ass about those higher frequencies.
G.
noisewreck said:3. Sometimes you just want to be able to annoy the neighbor's chihuahua![]()
Agreed on all points - especially the chihuahua, which in my next-door neighbor's case is a useless white somthing-oodle lap dog named Snowbellnoisewreck said:While I don't disagree with you that going beyond 20kHz (or 40kHz sampling rate) on recording/reproductive systems is usually an overkill, there are other technical reasons for doing so.
Well, you could get a pair of Yammi MSP-whatever monitors, pair them with an Earthworks and spit out stuff at 40kHzSouthSIDE Glen said:BTW, Even Snowbell is not that affected since my monitors can't reproduce that well that high anyway. They're designed for humans.
G.
No prob. This thread is as long as Snoop Dogg's rap sheet; I can't blame anyone for missing some of the stuff in the middle.noisewreck said:Well, you could get a pair of Yammi MSP-whatever monitors, pair them with an Earthworks and spit out stuff at 40kHz![]()
My apologies for re-stating stuff from earlier pages. I didn't have the patience to read through them all.![]()
Robert D said:You know, to paraphrase Tom "scientology" Cruz from risky business, "Sometimes you just gotta say fuckit and get on with making music".
Farview said:NO! The pixels equate to the bit depth. The number of bits is the resolution, the sample rate only affects frequency response.
Farview said:Now you are talking about the quality of the converter, not the conversion process. Two completely different things.
Farview said:Amplitude is what the bits do. The more bits, the more dynamic range. (amplitude).
Anything that happens below the nyquist frequency will happen with enough samples to be replicated. The timing issue is affected by jitter more than samplerate.
thavva said:So there's no specific problems in having different bit rates in one project? No any drop in quality?
Just to reconfirm. Is it not necessary to convert the bit rate fr 16 to 24?
Thanks for your reply.
*sigh*. I give up.TerraMortim said:yes, but the quality is also determined by the sample rate.
My point was that we weren't talking about converter quality, we were talking about the math involved. Two separate issues.TerraMortim said:There is no perfect quality converter however. Perfection doesn't exist in electronics or anything for that matter. Sure, it can come close tho. That's what I meant by degrees of perfection. It's simply a matter of how much less does this one suck ass at capturing shit![]()
Now you're just mixing things up that have nothing to do with each other.TerraMortim said:ah yeah, I think I know what your saying. I don't think I got my thoughts straight on that one lol. I would think the ammount of colours would equate more to bit depth. IE 32 bit colour and all that hodge podge...
Go back and read SouthsideGlen's long post on the last page. Keep reading it until you understand it.TerraMortim said:yes, but the quality is also determined by the sample rate.
danny.guitar said:Your software shouldn't have to convert the samples to 24-bit. If it were a different sample rate (which is also different playback speed) then it would probably need to or the tracks with different rates would go out of sync.
I've worked with samples that were 16-bit, in projects that were 24-bit and had no problems.
There's no drop in quality. The 24-bit files are left alone, no change there. As for the 16-bit files, they are either converted to 24-bit or they arent. If they arent, no change there. If they are, all that conversion does is stick 8 zeros onto the bottom of the value; no actual change in quality there, either.thavva said:So there's no specific problems in having different bit rates in one project? No any drop in quality?
