My point was, I've never had to put anything in front of a mesa to get it to do almost anything I wanted.Keiffer said:Sorry but I'm not sure of your point...
it's not about having to... it's about options... consider trying it sometime when you have time.Farview said:My point was, I've never had to put anything in front of a mesa to get it to do almost anything I wanted.
I've got too many amps. If the mesa isn't doing it, one of the marshalls will, or the Soldano, or the Bogner. If all else fails, the Pod. I remember using the overdrive pedals with the JCM 800's 25 years ago. I always hated how they tended to cut the balls off the sound, so I modded the amps for more gain. Distortion pedals just are not my cup of tea.Keiffer said:it's not about having to... it's about options... consider trying it sometime when you have time.
You've totally missed the point... so I guess they're just not your cup of tea...Farview said:I've got too many amps. If the mesa isn't doing it, one of the marshalls will, or the Soldano, or the Bogner. If all else fails, the Pod. I remember using the overdrive pedals with the JCM 800's 25 years ago. I always hated how they tended to cut the balls off the sound, so I modded the amps for more gain.
What is the point?Keiffer said:You've totally missed the point...
Boogie would like you to think that they are the only supplier of suitable tubes for their amps. If you tell the guy at eurotubes.com that you are running a Boogie, he will send you tubes that will work with the fixed bias.gcapel said:I would not use any other tubes than mesa. I know they are more $$ but they sound the best for the amp. That's why they are fixed bias. You can order the tubes straight from boogie.
Farview said:Boogie would like you to think that they are the only supplier of suitable tubes for their amps. If you tell the guy at eurotubes.com that you are running a Boogie, he will send you tubes that will work with the fixed bias.
