W
westermane
When you guys are recording drum machines, keyboards, elec guitars, etc. into your recorder - how do you set the volume? For instance, with my drum machine, I'm not sure if I should crank the volume to the max and then adjust the input levels, or if I should have a medium volume from the drum machine and then adjust the multitrack levels. Is there a correct method to this or does it not even matter?
Thanks!
Thanks!
