Which instrument is too loud?
  • Thread starter Thread starter LazerBeakShiek
Try sliding the gain control to +7.7 on the high shelf and then +4.8 on the low shelf.
You might have to go a little higher to get the same effect. When I A/B'd the SSL with the Nuendo EQ, it didn't sound the same, even with the same settings. The SSL was brighter and tighter than the stock EQ. YMMV
I am boosting everything above 8k, not cutting it. Also, i have a limiter on the master bus, which may have something to do with the reverb tails. I'll have to look to see how much reduction I have going.
Edit: I just looked and I have about 4.5db of reduction coming from a brick wall limiter on the master bus. Mostly, it seems to be knocking back the snare drum, which will bring up the reverb.
