L
littledog
MISTERQCUE said:
HUH!!?? What jazz have you been listening to?
Listen to Stan Clarke, Will Lee, Miroslav, Milt Hinton et al.
In Be-bop, where there's usually a trio or quartet (Miles,Carter,Tatum etc) where an acoustic is used, it's usually doubled mic'd with the low-end directed dead-center and the upper-register is panned slightly off center in conjunction with
harmonic portions of piano.
...most bass in jazz recordings have been placed center with the exceptions of earlier recordings by Blakey,Hines,Lee,Monk,Coltrane,Smith, etc who's ensembles were usually recorded via different means.
Brother Q:
I'm sure you are a fine bass player and musician, but I will admit I'm a bit confused by your sense of jazz history.
First, your use of the term bebop: Yes, Miles played bebop when he worked as a sideman with Charlie Parker. Art Tatum, though one of the greatest pianists in history, was not a bebop player, by anyone's definition. I'm assuming by Carter you mean Ron (as opposed to Benny?) but neither Ron nor Benny are considered bebop musicians.
Secondly, the classic bebop ensemble (the overwhelming bulk of which was recorded from 1944 to 1954) was five or six musicians, depending on if they used a guitar (or occasionally vibes). The front line typically had two horns. Which is why Miles Davis got so much work with Charlie Parker. When Parker was not paired with Miles, he used such other great players as Fats Navarro, Dizzy Gillespie, Red Rodney, Kenny Dorham, etc. And although you could point to piano trios of Bud Powell, (and Thelonious Monk - of whom it could be argued was "his own" style of player, not a bebop one) only a tiny percentage of bebop recordings were done by trios or quartets. And, of course, all the original bebop recordings (to say nothing of even earlier records by Tatum, Hines, et al) were MONO!!!
Thirdly, this method you describe of mic'ing the "upper and lower" registers of the acoustic bass... (aside from the issue that these were actually MONO recordings) well, on piano it's obvious how you would do that, but just how would one go about doing that on a bass? And how many recordings used this interesting method - do you have any specific engineers or records who used this panning you refer to? I make no claims to knowing anywhere near everything, but it sounds pretty difficult to isolate the high and low frequencies of an acoustic bass, unless you do it with filters in the mix, and I've never heard of this panning scheme. I'm eager to be educated, however.
Fourthly, in your statement "earlier recordings by Blakey,Hines,Lee,Monk,Coltrane,Smith, etc who's ensembles were usually recorded via different means..." you certainly cover a lot of historical ground here. An early recording by Fatha Hines would be at least thirty years earlier than an early Coltrane recording. What do you perceive that these widely seperated recordings have in common? Who is Lee? (Lee Morgan?) Who is Smith? (Bessie Smith?, Jimmy Smith?, Stuff Smith?, Fresh Prince?) I'm not being argumentative here - it just is not obvious to me who you are talking about. And could you please explain what are these different means of recording you are referring to?
Thanks for providing some interesting food for thought...
