R
rapedbyape
...How can you tell when the tubes in an amp have worn out? Do they just stop working, or begin sounding bad, or what? APologies for my lack of knowledge.
If you notice that the amp just doesn't sound right to you, check the tubes and try replacing them one at a time in the preamp section. Preamp tubes generally last much longer than power tubes though, and while some players replace their power tubes on a regular basis depending on how often and how hard the amp is played, they tend to leave the preamp tubes alone unless there is a problem. If you replace the power tubes, make sure that you have a qualified tech or experienced friend bias them correctly if your amp requires it. Also, especially if you are in a gigging situation, make sure you carry replacement tubes in your gig bag...you never know when you might need them.
Outlaws said:I had a Blues Jr. and it sounded like a freight train when I turned it on. Got new power tubes and it was solved. Scared the hell out of me though.
Buck62 said:The best way to tell if your tubes are starting to go is to turn on the head with nothing connected to it... no guitar, no speakers, nothing. If you hear noises, one or more of your tubes are on the way out. We just had it happen to a guitar player who recorded with us over the weekend with his Marshall JCM2000 head. The thing was crackling like a hamburger on a grill before anything was even connected to it. Definitely a bad tube. The crackling was audible in the recording, so his JCM head was unusable for recording. Fortunately, I had a backup amp, so the session was saved.![]()
Whoopysnorp said:Doesn't this damage tube amps though?
Buck62 said:How would that be?
Do you think a technician hooks up a head he's working on to a matching cabinet when someone brings it in for repair?
I doubt it.
