Spikeh
I've been recording for a few years now, and something's just popped in to my head... maybe I'm doing it all wrong? Although I know there's no right or wrong way to do things in the recording / mixing / mastering world, I'm sure there are "better" ways!
I currently record with some decent mics, in to a crappy Behringer MX8000 desk, that then goes straight in to an M-Audio Delta 1010. That's changing next week as I've purchased an RME HDSP9652 and 2 Presonus Digimas FS's, just in case you haven't seen my 5 million other posts with the same statement in it ;P
I always EQ on the desk to get a sound for the instrument / mix that sounds better than the raw sound. I sometimes run things through a pre-amp / compressor, but usually only vocals.
Now, I'm thinking, would it be better to record with a flat EQ, no gating or compression, then add it afterwards? I know this isn't the case for vocals (it always sounds better with compression on them), but as for drums and guitar, surely if I recorded them flat, it gives me MUCH more flexibility when I come to mixing? That way the recording can be done a lot quicker, and I just need to spend time getting the mixing right?
Or am I completely wrong with this assumption? The reason I'm asking is with the new sound card and AD/DA interfaces, I have the option to go straight in to the Digimax's XLR inputs and use their preamps, which I can guarantee will be better than the Behringers? It also cuts out a whole mixing desk (including the horrible channel / talkback bleed I get from it, and noise) and another 3 meters of TRS multi-core (from the direct outs of the desk to the sound cards).
Another question in relation to this is, what about effects? I have some really good VST plugins (I use Nuendo) such as the Waves Diamond Bundle, a TCWorks bundle and various other plugins... but I also have some semi-decent hardware units. Would it make sense to record everything clean then run it through VSTs afterwards, or record with the hardware in the chain? Or even run the recording through the hardware afterwards? Again, I would have thought the VSTs would give me more flexibility?
Thanks in advance for any responses...
