When recording distorted guitar...
  • Thread starter Thread starter RAMI
R
RAMI
Guest
I know I have to experiment and see what works in every different song and situation...But, generally speaking:
Am I usually better off using a dynamic rather than a condenser. (I know I can use both at the same time, but if you had a choice to use a 57 or a good condenser, what would you do?)
If I do use a condenser, do I put it right up against the grill like I would a dynamic?
Is it worth trying to use a 57 close to the speaker and a condenser further away? Or does the headeache of dealing with phase cancellation not make it worth it?
Fell free to answer on or all of these questions. Thanx
You're absolutely right; it totally depends upon the guitar, playing style, song arrangement and type of amp. BUT...probably 9 times out of 10 I'd personally start with a close-miked 57, for two reasons. First, because it is such a standard because it does work so well in so many situations. Second, because I have used 57s on so many damn cabs in the past (live and in studio) I have a good baseline in my head as to what kind of sound to expect, more or less, and if the resulting sound varies greatly from what is expected, I'll have a good idea as to whether to proceed with different placement, a different mic, etc.
That doesn;t mean that is what I will necessarily end up recording with. I may add a mid-field condensor, or substitute the 57 with a 421, or double up a 57 with a 421, or any combination of the above plus some. Or I may leave it alone. But regardless of where I end up, it's almost always a good solid place to start for me. Start with what you know and expiriment from there if necessary. Starting with a complicated or expirimental setup is just swinging at a moving pinata with a blindfold on.
The following is not set in stone, and others may have different legitimate experineces, but I rarely use condensors on heavily distorted guitar.
G.
Great advice. Thanx Glen. I posted the questions because I found that it seemed I was getting a better guitar sound when all I had was a 57 and no other choice. I kept it simple and it worked.
Seems like the 57 gets a lot of unfair criticism - personally, I think it's ideal for a heavily distorted guitar cab. It's like having the right amount of eq right at the source.
When i record distorted guitar I always use 2 dynamic mics,..well,..pretty much always. I'll put one at the grill and put the other distant( wherever sounds good). I suppose there aint no rule for using condenser mics with distorted guitar,..but i personally havent ever been able to get it to sound too good. But,..also,..with distorted guitar,.. I never just use those tracks. There are other things that i usually do to shape it more,..like combine a direct in signal with it,..mic the string attack of the guitar itself,..etc,...and I'll mix them in with it.
My two cents....
take 'er easy,..
Calwood
