Y
yorgo
When mastering, would puting a bbe sonic maximizer be a good so;ution to making a good mix better????
yorgo said:When mastering, would puting a bbe sonic maximizer be a good so;ution to making a good mix better????
Farview said:No. It would be like throwing the mix on the ground , pissing on it, stomping it a few times, then lighting it on fire.
ROFLMAOFarview said:Ooops! you are right. Fire first, water second. Eggs on top, canned goods on the bottom.
Cloneboy Studio said:I agree.
Sonic Maximixers on your end mix is... gross.
Now I'll use them (exciters--the Aphex ones) on occasion for cymbals or discrete tracks but NEVER for distorted guitar, vocals or an entire mix. It's just too gross to contemplate.
In my experience, this sort of setup will produce a thin, over processed type of guitar sound that is very outdated (think Top Gun soundtrack). You may have found a way to make it sound like something, but if the BBE made it sound better, I doubt it.gusfmm said:But, Why not for distorted guitars??? I don't think my guitar rig would sound so well without the BBE. Does it sound digital? I don't think so, perhaps just not as analog as some purist would like, but I use an all tube compressor and all tube pre-amp (distortion), digital FXs and then the BBE. It definitely kicks butt.
Farview said:In my experience, this sort of setup will produce a thin, over processed type of guitar sound that is very outdated (think Top Gun soundtrack). You may have found a way to make it sound like something, but if the BBE made it sound better, I doubt it.
I have no idea what your rig sounds like, but I have been riddled by guitar heroes with this kind of setup for about 20 years. If your stuff truly sounds great, you would be the first.
Track Rat said:I like the Urinator plug in by Uranus (makers of Brown 25).
Well, not for me either. How would you do if you wanted to play something a bit more elaborate than power chords (with all due respect to SG, I've got nothing against them)? Ever tried to play Vai? Ain't gonna sound right with justta bare cable. ahem... bullshit..... CDs seem to do fine at 16-bit/44.1KHz....... it's all about converter quality, not number of bits and sampling rate.gusfmm said:...with 18bit A/D/A 48kHz it is obvious that the signal can't get through uncolored.
