N
natpub
Hi all,
I am figuring that this kinda thread has probably been done before here, but I wanted to post it again anyway, since I am new to this forum. I had used a Digi001 set up, and they were constantly trying to post their max loads to test which DAW configs worked best, trying to crash their systems=)
To do this test, set up 24 tracks of audio to start, assuming you use Sonar2. Then, pop in 2 minutes of some kinda audio, loops or whatever, and copy it to all 24 tracks. Then pop in at least 4 real time effects on each track. If that hasn't crashed you already, hehe, then begin copying and adding more tracks and RT effects.
NOTE: When you start duplicating tracks, it is gonna distort no matter what, since you are doing addative dB redundantly. Just keep riding your input gain down until it stops.
Post results and systems here, including your sound card/interface.
I have not maxed mine yet, but I just ran a little test, and had the following results:
Audio Tracks: 24
RT effects per track: 4
Time Length of "song": 3 mins
Total CPU usage: 38%
Total Drive usage: approx 10% on avg.
As you can see, this didn't even come close to crashing the system. Using Digi001, this would come near to crashing or crash. Using Qbase, it would tax the system about double these results (I tried it). Using Nuendo, I believe it would be about even, though Nuendo is a pretty fucking awesome audio recorder, but Sonar adds all the kewl sequencing options. Using ProTools, yeah, OK, but hey, who has 10K lying around? If you do, plz lend me some cash! hehehe.
System:
--AMD Athlon XP 1700+ CPU
--ABIT KR7A-RAID mobo (all VIA chipset, heh, ignore the Aardvark claims that VIA chipsets sux, that is just plain wrong)
--Aadrvark Q10 using their latest A/WDM drivers (they ROCK!)
--Mushkin, 512mb of their pro line 2-2-2 (ownz)
--two Maxtor ATA133 40GB HDD's bussed on the Highpoint 133 raid posts on the mobo, but not run as a RAID. The second drive is dedicated for audio files.
Not a bad system, but not really all that bleeding edge. Future plans here are to switch to serial HDD as soon as they come available (seagate has some coming out this month, and Highpoint already has a nifty PCI card available to bus it)--if you dont know about em, I suggest you look--FAST. They are gonna change things alot and SCSI is bye bye.
Also, I am gonna dump the XP1700+ and go to the 2400+. Over 2400, you need the 333mhz fsb, and my mobo wont support that, so that will about top me out unless i loose the mobo, which i dont wanna do for a while. I'd rather spend the cash on a new Avalon micpre/comp/eq--damn those things are godly...
later all=)
Audio Tracks: 24
System:
later all=)
