SouthSIDE Glen
independentrecording.net
Ok, at some specific frequencies that could be a couple of dB. Frankly I just pulled a couple of condensor model numbers out of my ass to try and illustrate the greater point. To pick at that is to miss the forest for the trees.giraffe said:i'd be willing to bet that in the 15K and up area the differences between a
U47 and a B1 (i'm assuming SP) are much grater than 1/2a db.
When you have a difference in overall curve that varies from -.5dB here to +1dB there to -.75 dB there and back to -.5dB over there, it's not a difference that varies by a dB, though that's the maximum deflection. It's a difference that varies by a range of as much as 1.75dB in a single locale, and greater than that overall.
The sum of the differences builds across the spectrum as a much larger difference in perceived response overall. I picked the microphone example to point out that even though the differences in value in the curves are not large (they may be larger than a half dB, but rarely are they more than a few dB for any given frequency), the difference in overall sound is much greater than the charts make it appear. The same can be said, perhaps even more so, for monitors. The vast majority of quality monitors manage to show an extremely flat response from 40-15k. You'd think they all sounded the same. We all know how blatently untrue that is.
This effect is even more critical at the high and ultrasonic frequencies. A 1dB difference at 15k is a much larger deflection in terms of percentage of the total amplitude than a 1dB difference at 80Hz is. Put another way the diference between a 70dBSPL and a 71dBSPL signal at 15kHz will be much more audible than one at the same levels at 80Hz.
The bottom line is, what are apparently small differences in the overall shape of the stuff above 15k are actually quite audible (assuming, of course, one has the gear to reproduce it properly.) Moreso than at the more conventional frequencies. And it doesn't necessarily take a 3dB+ bump anywhere to be able to do that.
This is the stuff that makes the difference in both cost and sound between a $500 preamp, microphone, or monitor, and a $2000 one. It's not all just penis extention...unless the engineer behind the knobs is a knob.
G.
