-My budget is about 500 at the moment just need to get my feet of the ground and start recording bands$(for racks,mixers, or w/e i need only to improve my recordings.)
-Well i just need 8 sources and thanks to the firepod i have them just enough to record drums.
-Yea ima need mics i hav an SM57... but i need to get a drum mic kit i was thinking about a Nady mic drum set of 7 mics that i saw in musicianfriend for 200$( i know not the best mics but they have good reviews i dont have 350 for a shure mic set of only 4 mic)
-At the moment i have a Comp16 which im selling soon. I just started so that why im asking for help so i can invest in more useful equipment.
-Im using Nuendo 3 with Mostly all waves plug ins and a couple of more.
My PC specs are.
Windows xp
AMD 64x2
Ram: 2 gigs
two 200gb hard drives
-Right now im looking for good Active monitors around the 250$ (pair)
aren't the firepod preamps good??? if not are Art tupe good.. since im on a low budget.
Get back to me as soon as possible Thanks!
xmortumx,
Alright, this could be fun suggesting how to spend your $500. You've got a good start with your PC rig, DAW, Plugins, Firepod and the SM 57 (so you've already got a snare mic, guitar cabinet mic). As you'll see (or soon will) you can spend a little money and buy crap or barely workable gear and spend a fortune as well. Soon you'll be plagued with Gear Acquisition Syndrome (GAS) like many others. With recording gear, most of the time you get what you pay for. You constantly upgrade your studio (read -SPEND MORE $)
With a $500 budget you'll have to get by for now with the 8 pre's in your Firepod. As I see it from what you've explained the priority is you need at least 2 more mics and some near reference monitors. Initially, you'll be limited by how many sources you can track (record) simultaneously by how much gear you have. For now a bass player can use a direct input on your firepod. If the guitars use an amp/effects modeling unit then they can be directly inputted too. If they use an amp/cabinet they'll obviously need to be mic'd.
I'd like to see you spend twice your budget for just the reference monitors but that won't fit the budget.
For drums you can record them with just 2 mics, thoughtfully positioned. I'd suggest condensor mics for this application.
I'm proposing :
1)Two condensor mics (for drums, vocals, etc).
2)Active near reference monitors.
With this you can then simultaneously track drums (with 2 overheads) / bass by direct input and then 1 guitar cabinet with the SM57. Vocals, more guitars, other instruments would then be tracked on a second pass.
You won't have a headphone system for the musicians except one headphone output on the Firepod.
You could (and should) sell your compressor for some cash for a headphone distribution amp. I believe Pipeline is interested in your compressor. You can get a compressor later. You'll just have to use technique to get by without the compressor plus I'll bet you have some compressor plugins?
So group, what are your suggestions for 2 condensor mics and a pair of active near reference monitors for our budding recordist xmortumx with a budget of $500? I'll post some suggestions later. For now I need to visit some other forums and piss others off too!
Hope I'm making some friends here.
