What is this noise and how do I stop it?
  • Thread starter Thread starter kristian
kristian
kristian
Does anyone recognize this cyclical noise? It isn't 60Hz, I think it's from my laptop. When I record electric guitar it will come out of the amp as well. Thanks.
Probably the power management in your laptop cycling the CPU speed. Not sure if there's anything you can do about it except making sure your laptop's case is properly grounded.
Oh, it might also be power cycling on your laptop's wireless hardware if you have Wi-Fi or Bluetooth turned on. Try disabling that and see if the noise goes away.
my laptop makes a funny noise when running on battery....
are you on battery,,and if so, does it do it plugged in?
dgatwood - "power management in your laptop cycling the CPU speed" - Can you explain that a little more or send a link? I've turned off the wireless interface without results (HP dv2000, has an external switch). The house I live in is brand new (2005) and I use furman power conditioners. My guess is that grounding would be properly taken care of in new construction. Hmm...
Steenamaroo - Plugged in to the wall, but the battery is still in. When I get back after the holiday weekend I'll take out the battery to see if it helps. The alternative is to use my old desktop for tracking. I built it in 2004, so it's getting a little slow for mixing but it can track like a mofo.
happy thanksgiving.
