P
publicradio
Hey all,
First of all, please pardon my mess. second of all, understand that like many of you, I am in a very tight economic situation.
Now that said, I live in a coop in Chicago and we have an absolutely beautiful and amazing music room. I am in the process of turning it into a functional recording space. I've fixed, strung up and tuned up all these great musical instruments, although i can't play most of them. I have some really nice high end Kenwood speakers that function just fine as monitors for me, for now. I have a Behringer B-2 pro condenser mic. this is what the room looks like:
I've put the foam I have up around the room just to test it out. Here's what I have:
Two squares of eggcrate foam, the size of large pizza boxes
Two blocks of stiff, relatively dense foam pulled out of loveseat cushions
Another, big piece of foam from the same loveseat (note: there was obviously a big burn in this loveseat)
Four strips of flat memory foam matress pad
An eggcrate-formed piece of mattress pad
Another pad, cut in half, with an egg crate form, only less deep
Another flat foam pad, from that busted loveseat I mentioned earlier
So anyway, I stupidly tried to make a soundproof both in the closet before, and it was too damp. Also who wants to sit in a closet all the time? now my foam is all cut up into irregular sizes and full of staple holes. I was thinking of spraypainting it all black and trying to cut it into equal-sized squares. Maybe the paint would make it less absorbant, I don't know. I was also thinking of cutting the thick cushions into logs and using them as bass traps, and then going out into the alley for some plywood to use as diffusors.
One wall is painted concrete; the other is painted brick. The ceiling is concrete with a half inch of that kind of drywall you stuck pencils into during detention as a kid. the floor is painted cement with a raggedy rug on it.
The loudest real drum that will be used in this room will probably be the djembe. I don't forsee getting a drum kit. The guitar and bass guitar are most likely just going to be line in to the computer with a virtual amp, although I might use the amp you see in the picture.
So what do you think? What can I do with what I have??
thanks so much in advance,
Morgan
Morgan
