sonusman
Banned
Okay, lot's of mastering threads. I never give out much....
Call it not going somewhere until I am dressed up!
Anyway. I am not a proponent of "loud" in mastering. I would rather augment what is there. Maybe a bit of limiting, but not too much, unless that is what the client wants.
Here are three Fraunhofer codec encoded mp3's, all at 192kbs done in High Quality mode, of the same mix. One is the Original, one is Mastered (the first time I mastered it to about the clients approval), and one Loud (I at least doubled the amount of limiting over the clients version).
I am torn myself between the Original and Mastered. Original just sounds so pleasent to the ear. Nothing abrasive or choked. It was the way we wanted to mix it within the 5 hour time frame we had to mix it and the lower end type of tools available.
Mastered is pretty nice though. I was able to get a bit more definition, and quite a bit more level. It seems to "rock" a bit more the original. But, I am not terribly fond of how the "depth" of the mix sort of got lost. Yes, it is louder and punchier, but it doesn't seem to be as pleasing to the ear. The warm sound started to go away. Instead of a sort of sweet top end, it is a bit harder and colder.
Loud is just plain too loud. I really didn't spend that much time on it. Coming out of the Bass solo you can really hear the limiter grab ahold! This is what I hear a lot of on some major label releases, and hear very distinctly on many mp3's I download from people who are not well versed with using limiting, and how you might need to eq before the limiting. I don't like loud mainly because it has no character anymore. It starts to turn to mush. The dynamics are very flat which robbed the song of it's charm. You can sort of hear the fuzzyness so much limiting produces. I think I could have spent a bit more time on Loud and taken care of some of the limiter grab things and mostly retained this level. But for the most part, Loud is around what you would here on many major label releases in terms of RMS level.
What is my point here? Loud is not always so good. Make sure to listen to Loud first. It really doesn't sound all that bad.
Don't listen for whether you like the song, or per se what you might have done differently in the mix. Listen to how listenable the different mixes are. Listen for the little "ear candy" things, sweet top, rich bottom, smooth dynamics.
Listen to Loud first, then Mastered, then Original. Give each a couple objective listens. Ask yourself, which was the most pleasing to listen to. Go ahead and turn up your monitors to match the level of each song. Please don't use software volume to adjust as that would introduce DSP, thus coloring the results. You will have to turn Master up a bit to sound as loud as Loud, and Original up a bit to sound as loud as Mastered.
This whole thing will be very revealling if you really listen to the listenability of all three versions.
I believe most will favor Original at some point purely on listenability alone. How friendly it is to the ear. Mastered I feel is acceptable, but not quite as enjoyable to listen to overall. Loud is just plain annoying unless you didn't hear Mastered and Original.
Let me know what YOU think. Was raising the level REALLY worth it?
Go to: http://www.xdrive.com
At Login enter: SoundCracker (exactly how I just spelled it, with no spaces and the same capitaliaztions)
Password: mp3s
Ed
Call it not going somewhere until I am dressed up!Anyway. I am not a proponent of "loud" in mastering. I would rather augment what is there. Maybe a bit of limiting, but not too much, unless that is what the client wants.
Password: mp3s
Ed
