VS-880 VXpanded Effects
  • Thread starter Thread starter DJTonyMOMO
D
DJTonyMOMO
Well I own a VS-880. And I was wondering how to use the effects to each track when I try to do so All i get is an Option of like 3 effects total. I know there are more effects then that. can some help me out? Thanks
You must be more specific, and we will be glad to help....
Darth
More info would help.
As a peliminary matter, there are only two effects processors in the VS880. At best, you can insert four tracks through each processor if you are using stereo effects in each processor.
I'm not too sure how your wound up with three.
Sorry for not explaining Well
Yeah I'm sorry I meant 4, but I thought there was more with the VS Xpanded unit I got?
Yes, there are SEVERAL more effects. I used to have an 880, but now I have a 2480, and I can't remember the buttons to press. If you look in the manual under "applying loop effects" or "loop effects" or something like that, then it will show you how to use delays, reverbs, choruses, etc. If you look under "effects insert" it will show you how to use compression.
If you use a loop effect, then you can put up 2 different effects on as many channels as you want, if you use an insert, then you can only use 2 inserts on 2 channels, unless you insert it in stereo, in which case you have to use the same parameters for both tracks.
It's a lot to write out, but if you have the manual, it's spelled out pretty easily in there.
Hope this helps!
Darth
Damn once again..........
Once again Darth you are the man. I will have to try it out tonight. I'll get back to you tommorow with my results. Thanks again Bro. Where you from darth?
Hey Darth
Do you have a website or some pictures tht I can see your home set-up. Just wondering. Thanks
Hey Darth?
Do you have a website or some pictures that I can see your home set-up. Just wondering. Thanks
I'm from Nashville. I want to get some pictures of my setup soon, but I just can't ever find the time to make it look nice so that I can take a picture of it! I'll try to get one soon, though.
Darth
Come on Darth...I've been dying to see your setup too...Dont hold out on us...We really need this...
