R
ryansharif89
My friend and I just had a long discussion about the use of compressors versus manually adjusting the levels in real time.
In my opinion, using a compressor is the only real way to smoothen out the levels on a track, so that when a singer raises his voice to hit a higher note, it will come out the same volume as when he/she was singing at a regular volume.
According to my friend, you can manually make the volume lower at those particular points of the song just by using the volume control on the EQ; apparently the volume slider will go back to it's original state when the singer does.
If this is at all possible, can anyone explain the process to me?
thanks.
thanks.
