Hi all,
I'm having trouble posting this in the Line 6 forums; so posting it here for now to see if anyone can help..
I'm screwing around with the Red Squeeze compressor effect on my Line 6 HX Stomp XL. I'm a bit confused about the "sensitivity" control for this effect. According to the HX Stomp manual this effect is meant to model the MXR Dyna Comp. effect. So I looked at the manual for the MXR Dyna Comp. and it also has a sensitivity control, which the manual says controls the compression ratio... So then one would expect that turning up the sensitivity should raise the compression ratio, which in turn should lower the volume of the output given that we're compressing more of the signal. However, when on the HX Stomp I raise the sensitivity it actually seems to increase the volume if anything (the exact opposite of what I was expecting).... So what exactly is the sensitivity doing here?
Any help would be appreciated.
Thanks!
Thanks!
