G
glynb
Balladeer
My view is that the ends always justify the means.
So if getting it down in one produces the desired result, great, if it takes a hundred overdubs to get the great result, fine.
My preference would be to do a great vocal take in one go, you're capturing a performance that way, not piecing together an amalgam of various performances.
But if you took that to extreme, then a band should only be recorded at once in a single take - but that might not result in the best end product to listen to repeatedly on a recording.
I usually do a one take as the main vocal, then sometimes re-do a faulty verse, or a couple of lines, or chorus from the last convenient break. this is on the same day/session.
if i come back another day and think the vocal is not good enough, i generally re-sing the whole thing from scratch. You can often tell when it's been recorded done at different times when the mood has changed. Knobs may be tweaked differently, settings altered, mic not quite positioned the same way, etc.
