Z
Zed10R
Active member
Freudian Slip said:I don't know where you get that from![]()
I get that from the talk about how great adlibs and spontinaity are. I guess it all comes down to personal preference...
I personally think that your way better off with one take with no punches or fixes. The point of singing it 2 or 3 times all the way is that if you have a good singer that knows the song, you have a good chance of pulling it off. If not you have a good chance of robbing from another take that will match in intensity & emotion beacause the line or word will be taken from the same part of the jouney threw the song (for the singer) as what you are trying to replace. If the singer was starting to get a little short on air it will be the same in all takes. Where as when you punch the singer could likely have a full lung of air and it would sound out of place.
In the case of rap with the critical timing issues for fast phrases that are going to be blended, doubled, etc. I can certanly see a several take process just because of the more demanding rythmic qualitys of it.
I can also see punching every verse as an effective way of maintaining consistansy and power if need be. I just don't see two word here and there.
And of course if want to pay me good money to do 20 takes. Guess what. Twenty takes it is. Hell I'll set loop record and see you in a half an hour.
I guess if you got people beating down your door you can be choosy if ya want.
I'd personally rather turn down the skin head hate band and work with a younger band that is not super dooper, but pretty good.
Just my opinion.
F.S.
Granted that really good singers can avoid mistakes in an entire performance, a lot of singers will cringe at their own minor 'goofs' even though to someone else the part sounds fine.
So, if you are the one doing the recording and the singing, then you are probably more inclined to redo a line or two.
The down side is that the levels might not be precisely the same if you punch in, especially if you come back on a different day.
How often do you record something, feel it was special, then a day later it suddenly sounds a bit ugly?
I can usually get it recorded in 1 take.
