D
DJ_Skull
I Wanna Know the Effects needed by a RAW vocal to make it sound good to the listeners..
Mixing. And tracking for that matter.Vocal Mastering or Mixing
Word to that. A quality voice (singing quality material) followed by a quality mic that works well with that voice in the context of the mix going into a quality preamp and (etc., etc., etc., yada, yada) followed by whatever effects you need on that track to make it the way you want it to fit into the mix.Singing lessons
"Vocal mastering...?"
You might compress it, you might EQ it (both quite minimally if everything above is covered or more aggressively depending on how you want it to fit), you might add spatial, modulative or time-based effects... It's really up to you.
It would help to be a little more specific with your question. Some genres run a little more 'natural and less effected than others for example.I Wanna Know the Effects needed by a RAW vocal to make it sound good to the listeners..
'good to the listener, might that mean 'expected for a style?
Still.. you need to pare this down. You can't go 'i need 2 kook a dinner and mixed up on when to boil' or fry..?
Start with what you know (so others will know what the heck..), and focus on one thing at a time.
Have you tried ths?
For example I googled double tracking vs delay and the very first two things...
Why would you say that
We finally got a specific question and guess what; a specific answer ..in less than an hour no less
yo man dnt even try to go no further with these guys on getting help
they ant gne do nun but talk bad about yu and eventually it will turn into a race thing and end up in the cave forum
yu wont recieve any help man...try other forums like futureproducers.com or raproyalty.com they are more helpful man
trust me stop while you're ahead
Yeah, everyone here gets treated the same as far as I am concerned. Unless they pull the race card themselves, it does not come up.
I work with some 'Hip Hop' genres sometimes. I find that any type of spoken 'rap' type verses, do not usually lend themselves to the double tracking thing. Though, there are times where a bridge seems to need something different. It is all about what the song needs.
Also, doubling a vocal track does not necessarily mean that you use both tracks at the same volume level. Placing one track, at a much lower volume than the main one, can help to define the part. You can also manipulate the second track, with distortion, heavy compression, pitch modulation, etc.. This is where it comes down to what you, as a producer, feel any particular song needs. Hell, that is part of the fun of it all. Experiment, and come up with something original.
Most music genres need some type of transition between sections of a song. What that is, and what is needed, is exactly what the term 'producer' is meant to describe. If you are doing it yourself, experiment, and find what works for you and the song. There is no wrong or right. Experience in finding exactly what works, is not a plugin, or any particular setup. It is the same as writing the tune to begin with. Create/experiment/learn....
Well the singing part has autotune set very hard to get that t-pain effect.
The verse has a delay.
I can almost guarantee eq and compression is being used too.
This is what happens when first cousins marry. Frickin' sad.yo man dnt even try to go no further with these guys on getting help
Is it advisable to pan left and right some of the tracks in vocal doubling???
