TelePaul
J to the R O C
Outlaws said:95% of the time that will be a bad tube.
Yeah, I've been hearing this quite alot now, so I'm definetely ordering a JJTesla, even to rule the tube out as the problem. Thanks!
I got mine from www.eurotubes.com. Great service, fast delivery, good prices and excellent tubes. All around good folks and I will definitely be ordering from them again.TelePaul said:Where does one get a JJ/Telsa Wade?
TelePaul said:Yeah, I've been hearing this quite alot now, so I'm definetely ordering a JJTesla, even to rule the tube out as the problem. Thanks!
Outlaws said:When you get it, shake it first next to your ear. If it makes any sort of rattling sound, it is already bad and will only get worse. Quality control is not what it used to be on anything in this world, and it holds true for tubes too.
ocnor said:Yes they are all 12AX7 type tubes which are 12 volt and use the same pinout. A JJ/Tesla ECC83 would be a good choice for your amp.
capnkid said:Actually RCA N.O.S. would be better.![]()
i totally agree. i'd put an RCA (or GE) NOS into a fender amp or something where you're looking for sweet and clean and good headroom.Outlaws said:Not for a Marshall AVT. Nothing wrong with the amp, but the sound is not exactly defined by the tube.
again, totally agreed when it comes to "off the shelf" tubes you buy at the local GuitarMegaLoMart. that's why i like a service like tubedepot or eurotubes--they make sure that what goes out the door is a quality piece. jay at eurotubes is the man.Outlaws said:Quality control is not what it used to be on anything in this world, and it holds true for tubes too.
mrface2112 said:thank goodness tubes are cheap as long as you're talking only 1 or two preamp tubes...
