TelePaul
J to the R O C
Are all valve series interchangeable? Like if I want a new ECC83 for my Marshall AVT can I buy any va;ve that says ECC83 or does it vary between manufacturer?
mrface2112 said:an ecc83 = ecc83 = ecc83 in terms of pinouts and 'compatibility'.
by all means YES try different valves from different manufacturers. new/different valves are about the easiest and cheapest mod/change you can make to an amp and can often be quite dramatic in sound.
cheers,
wade
+1 for the JJ/Tesla. I refitted my silverface champ and my epi VJ with JJ's from eurotubes and they really sing now. MUCH nicer than the ElectroHarmonix and Sovteks that were in there, respectively.ocnor said:A JJ/Tesla ECC83 would be a good choice for your amp.
ocnor said:What problem are you having?
ocnor said:That could be the tube. Does it rattle on the clean channel as well as the distortion channel?
TelePaul said:It seems to be rattling only on the clean; hoenstly, I can't hear it under the distortion. It's annoying, but only seems to happen on certain notes. I might open up the reverb tank tomorrow. It's the only thing - along with fitting a new valve - that I have yet to check.
boingoman said:In anything that has tubes in it, the tube is always pretty much the first thing you check. Quick test- with the amp on and volume up, rap the tube with a pencil or something. You'll be able to tell if it's microphonic.
That sounds more like a problem with the speaker. It could be that the speaker can't handle the lows at the volume that you are playing. You might need to use a compressor pedal in front of the amp.TelePaul said:It seems to be rattling only on the clean; hoenstly, I can't hear it under the distortion. It's annoying, but only seems to happen on certain notes. I might open up the reverb tank tomorrow. It's the only thing - along with fitting a new valve - that I have yet to check.
ocnor said:That sounds more like a problem with the speaker. It could be that the speaker can't handle the lows at the volume that you are playing. You might need to use a compressor pedal in front of the amp.
mrface2112 said:+1 for the JJ/Tesla. I refitted my silverface champ and my epi VJ with JJ's from eurotubes and they really sing now. MUCH nicer than the ElectroHarmonix and Sovteks that were in there, respectively.
cheers,
wade
Track Rat said:
TelePaul said:A ringing undertone, like somethign is rattling inside the amp....but I opened her up and checked thoroughly.
