B
BrettMckinney
Ok..first time with a sound card capable of 24/96..i just upgraded from an audigy. Now firstly, what drivers are the best to use..i had use mme even when wdm are present ticked and had some wierd sounds, so i unchecked it and did the wave profiler and now using the wdm. It shows way more inputs etc..dont know which to use..have been using AP1/2 or multichannel..dont know the difference.
So what is the best rates to set the project too? I've put it to 24 bit and then 48kz..should i go right up to 96?
Here is the biggest problem. If i record a track..say guitar, then i un-arm it, and arm a new track and record vocals over..the new track has recorded the guitar in it aswell. What causes this? Never happened on the audigy..im guessing its a setting in Sonar? THe other wierd thing is that if i listen to the track in sonar its really loud..and if i take it to Soundforge 6 it sounds way quieter!
Getting very confused. Would appreciate some ideas!
