B
bewildered
huh, it doesnt even say "out", it just says "main", whatever the hell that means.
solo.guitar said:Never get a clean signal with a PCI card?Some cards do make some noise because of interferance with other parts in the computer, but well built cards don't, at least not to the point where it's audible.
ofajen said:Please explain this. When I read about PCI Express, such as in the new Mac Pro, it claims to be backward compatible with PCI, meaning PCI cards will work in PCI Express slots. So, what's the big deal? Seems like PCI gear should be usable for many years to come.
altitude909 said:Bingo. As long as business use PCI based hardware (which is alot) PCI will be common on PC's. We have almost $50k invested in PCI DAQ hardware and if PCI goes away, we just wont upgrade those computers.
altitude909 said:PCI is still faster than firewire and unlike firewire, has DMA and u cant beat that for audio
dgatwood said:The only way you can guarantee a clean signal with a PCI card is if the converters are in an external box with a separate power source, sending the signal back to the computer digitally (e.g. the Delta 1010).
As long as the card is inside your machine and is powered from your computer's power supply, all it takes is a noisy power rail or a ground rail that's not perfectly grounded and suddenly your interface is generating chirping noises or other lovely artifacts. I've seen it happen with the Delta 1010LT, for example.
Fetusborg said:so with the delta 44, my drum will have at most 4 tracks. lets say kick snare hh and overhead. what do pro recording studios use to record like 8 drum tracks at once? do they have like a 16 track soundcard or do they link a few deltas together ?
