unwanted echo when using sonar or pro tools
  • Thread starter Thread starter distortedrumble
distortedrumble
distortedrumble
all up in yo grill!
i get a delay of voice transfer when it goes from the mic to the soundcard/software and whatever else it does before it comes out the speakers....it also echos on itself like an automatic delay. recorded the files dont have the echo....i know its something around the bit rate going from safe to fast but of course you know fast will make do an audio dropout when it gets going...how do i remedy this? i'm thinking a better sound card and more memory but fill me in on ideas setup is behringer ub802, audio technica cardiod mic, 1.7 ghz celeron, 256 mb memory, windows ME, biostar onboard audio, sonar 2xl, fl studio, acid pro and various other software
Don't be offended, but I'm having a hard time understanding your post. Let's try to separate the problems.
1) You say you get a delay of voice transfer when it goes from the mic to the soundcard/software and whatever else it does before it comes out the speakers....it also echos on itself like an automatic delay. recorded the files dont have the echo....
So you only hear the echo while recording but not during playback? I suspect that during recording the speakers are being fed by both the direct signal (from the mixer channel outputs) and the recorded signal (from the computer). The echo you are hearing is the time it takes the signal to pass through the mixer, soundcard, and computer, and then return to the mixer. Some how you need to turn off one of these paths to eliminate the echo.
2) you say you know its something around the bit rate going from safe to fast but of course you know fast will make do an audio dropout when it gets going.
Are you talking about the latency settings (sometimes called buffer size) in your soundcard or the conversion rate and word length being used (44.1 Khz, 48 Khz, 16 bit vs 24 bit etc)? I don't know what to say about this other than to start with the default setting recommended by the sound card manufacturer and adjust them until you aren't getting dropouts.
As far as suggestions for a better computer setup...
1) Loose the Celeron and get a Pentium 4 machine with 2 hard drives (one for windows and your tracking software, one for your audio files). Get rid of Windows ME, use Windows XP, or maybe go the Macintosh route.
2) Get as much RAM as you can afford.
3) Go to an outboard audio interface like M-Audio, Aardvark, Tascam, etc. There are lots of reasonably priced units out there these days. Search this message board for info.
Good luck, let us know how you are getting on.
yeah its the latency. i checked up on that. and theres a few ways around it....mine has a mono mix and a stereo mix on recording...when either one is turned up and has the select button on them...the recording meter will go bonkers before it even gets a signal to it...however selecting record fixes that problem....the other thing is turning the computer sound up and the mixer sound down records at the same level minus latency annoyances.....but its all good. now the question is...spend 500 in comp upgrades for recording or rig upgrades for playing out....might have to flip a coin
