The answer is to make another slipsteamed XP with the correct F6 extracted driver. Note that there is a 32bit and 64bit XP driver.
Here is another better link to slipstreaming:
Beginners Guide: Slipstreaming a WindowsXP Install CD with Service Pack 2 - PCSTATS.com
also see:
Intel® Rapid Storage Technology (Intel® RST) — No floppy drive for F6 install of RAID driver on Windows XP*
Lastly I just realised that I advised that you download SP2. This should have been SP3 which contains all previous SP
regards,
Beemer
Hey Beemer. I am sure I had the right drivers. I think the real solution (if I wanted to reload) would be to go and buy a floppy drive for $3.00 and use the disk that came with my MB
The intel drives from the site come as a to two part package, an installer.exe and a zipped driver package. The driver package varies depending your system 32 or 64 bit. It seemed like I slipstreamed them correctly but, there was some question as to how to package the drivers & exe for slipstreaming. EG: leave the drivers zipped, unzip them, include the .exe?
Anyway it's all up and running now. Good old wdm drivers. I can drag, copy, add or remove effects while playing back with NO hiccups. I can change a looping region while playing with out freezing, etc. I did a test of a drum recording with about 15 tracks playing back I recorded 9 drum tracks at 24 bit and let it loop 4 times.
I am not as happy with the software Raid0 as I had hoped I would be but it's not bad. With all those tracks playing back with effects (at least 50 tracks) I was hitting around 50% on my hard drive meter. You get a bit of a flare on startup but it calms down after that.
I have not tweaked anything yet either so I have to make sure DMA is on and that indexing is off. We will see what that gets me.
The CPU is sitting very pretty with a fair number of effects running so it does not look like much power is going to running the raid software.
I am going to find a had drive testing program and see if the (software) raid gets me the almost double speed I was hoping for. If the meters are right I would say that it's not that much of an improvement but, I don't know how sonar would know my exact max speed. I don't recall it running a hd test...?
Got to run guys. Thanks for he help. I will let you know what I find out. For now I am happy and happy to say SCREW windows 7. If it aint broke don't fix it. What a waste of time!
I will however me loading win7 on our laptop as it does kick vista's ass.
F.S.
P.S. Ya I did SP3. That went smooth as silk using nLite.
