unpleasant high end in vocals
  • Thread starter Thread starter Zed10R
I am willing to bet that those links which state that the vocal range is "300Hz to 3500Hz" are taking their info from Bell Labs white papers regarding the filtering required on both analog and digital trunks for the spoken vocal range. I am a telecom engineer during the day and I will have to look in my files for this white paper.
Speech fundamentals occur over a fairly limited range between about 125Hz and 250Hz. The fundamental region is important in that it allows us to tell who is speaking, and its clear transmission is therefore essential as far as voice quality is concerned. Vowels essentially contain the maximum energy and power of the voice, occurring over the range of 350Hz to 2000Hz. Consonants occurring over the range of 1500Hz to 4000Hz contain little energy but are essential to intelligibility. For example, the frequency range from 63 to 500Hz carries 60% of the power of the voice and yet contributes only 5% to the intelligibility. The 500Hz to 1KHz region produces 35% of the intelligibility, while the range from 1 to 8KHz produces just 5% of the power but 60% of the intelligibility. By rolling off the low frequencies and accentuating the range from 1 to 5KHz, the intelligibility and clarity can be improved.
Here are some of the effect EQ can have in regards to intelligibility. Boosting the low frequencies from 100 to 250Hz makes a vocal boomy or chesty. A cut in the 150 to 500Hz area will make it boxy, hollow, or tube like. Dips around 500 to 1Khz produce hardness, while peaks about 1 and 3Khz produce a hard metallic nasal quality. Dips around 2 to 5KHz reduce intelligibility and make vocals woolly and lifeless. Peaks in the 4 to 10KHz produce sibilance and a gritty quality.
Here is a link to typical frequency ranges.
http://www.listenhear.co.uk/general_acoustics.htm
Garry Sharp said:
Yes, i thought you'd have difficulties trying to EQ it. Can't you get hold of a different mic?
Yeah...I'm scrapping the idea of using that thing. I'm getting an AT4047 to replace my ADK Vienna and a Sennheiser MD421 to replace the troublesome AKG. Problem solved.
It's just a bummer because I'll need to track these vocs again and the old AKG sounded GREAT untill it hit that specific range....oh well.
I think you all for your very informative responses..... :D :cool:
