E
		effectsnut
what the difference between unballanced or ballanced cables?
and what applications..? thanks
sorry... no....Outlaws said:One is grounded.
amt7565 said:Balanced cables carry a signal over 2 wires(apart from the ground). However the signal is split and one end is shifted by 90 deg in phase. Doing so lets the signal travel longer distances and also reduce noise.
 In a balanced connection, one leg has its polarity reversed (180 electrical degrees out of phase); at the recieving end the inverted signal will be "re-inverted" and combined with the positive signal, thus cancelling any noise that was induced in the cable run.Almost... but not quite... the receiving end does not re-invert and combine the two signals, but creates a signal that is the difference between the two. Since the two signals see virtually the same impedance, any noise is equally induced on the two lines and thus is subtracted out, leaving only the audio signal.DigitMus said:...at the recieving end the inverted signal will be "re-inverted" and combined with the positive signal, thus cancelling any noise that was induced in the cable run.
Huh?amt7565 said:Yes, basically one signal will be phase shifted. For example if one is shifted by -45, then it is added(but actually subtracted since its -). So +45 and -45 will cancel out, eliminating any noise.
 Not necessarily... if you record a kick drum, and you flip the polarity, do you hear a difference? Some people do claim to - last time I tried I didn't hear a diff.DeadPoet said:remember to use the right polarity of your cable or the sound won't pass through and you'll get a thi out-of-phase sound !
Errrr... not ?
Balanced signals are not considered phase shifted. They are normally referred to as reversed polarity. But, they are 180 degrees out of phase. Phase shifting is generally reserved for time shifting of signals. This almost amounts to a distinction without a difference, but the difference in terminology does better describe the situation.amt7565 said:Yes, basically one signal will be phase shifted. For example if one is shifted by -45, then it is added(but actually subtracted since its -). So +45 and -45 will cancel out, eliminating any noise.
VSpaceBoy said:This is probably a dumb question to ask in here with all you smart folks but.. With the small amount of electricity that an electric guitar produces, would it make sense to use a TRS ILO the std unbalanced from the guitar to the floor? Or from my effects to the amp? so on and so forth?
No... that's considered a single-conductor....Steve Walker said:Unbalanced cables have 2 conductors (sig, ground)
No.... that's considered 2-conductor.Steve Walker said:Balanced cables have 3 conductors (sig+, sig-,ground).
