tkingen
Djembes Rock
I'm using UAD-1 4.0 plugs as per clip effects in Wavelab 4's Audio Montage. When there are 2 or more plugs in the clip and you check the bypass box, it seems to either disable both plugs permanently or cause crackling. Also, the UAD-1 usage meter increases by about 30% for each plug. Is this normal?
None of this happens when using the plugs in the master effects section.
Thanks in advance for any wisdom on this.
