Buck62
噛んでくれ
Okay, I have a Westbury Standard (Japanese-made SG) in which the "G" string goes out of tune. The G string makes a slight 'pinging' noise at the nut when I re-tune. I figure that the groove in the nut for the G string is either too tight, or the guitar was strung with .010's or .011's before I bought it two weeks ago, and the nut may have been originally slotted for .009 guage strings.
Now, since the string is slightly binding at the nut, this causes my tuning peg for the G string to loosen up when I re-tune, causing about 1/4 inch play in the tuner. I've tightened up the little screw at the end of the tuner and that seems to work... temporarily... until I play for awhile and run into the same problem again. I was told to rub a bar of hard soap into the groove of the nut, to give better slip on the G string, and I'll try that. But I have to wonder if it would be better to just replace the stock nut with a graphite or TUSQ nut. I'm also wondering if the tuning peg is about to crap out and if it will need replacing, since it comes loose and needs re-tightening from time to time.
Anybody here have a similar problem?
I'm open to suggestions... thanx.
