That's a very small price range. The Audio Technica 4060 fits in their and gets good reviews.
I suggest you either raise your budget to about $1000-1500 (so many options open up at this price point) or consider getting a used MXL V77 or V69, which should run you $2-300, and then save up for the more expensive Peluso, Pearlman, Neumann offering.
+1 Good advice. There's sort of a gap between the sub $500 mics -- MXL, SE etc and the better LD tube mics. The AT-4060 and some of the GT mics are the only ones that come to mind quickly in that low-middle range.
The AT is a very good mic and well worth considering. Of the current GT mics, I'd consider the GT67 and GT40, but I'd also look and see what I could find used in the prior models (e.g., GT-44, AM-40 which I believe are essentially the same mics with slightly different casings). You should be able to get a used prior model much cheaper than the current versions.
Of the current GT models, I like the GT40 (prior models AM40, GT44). I have a couple of these (prior models) and they are great acoustic instrument mics. Actually I like the first series of GT mics the best, before they went to the sub-miniature mil spec tubes - MD1, MD2, MD3 and the "a" versions of those mics. They all had full size replaceable 12ax series preamp tubes. Those can fall into your price range and are well worth considering if you can locate one. The MD1b resissue is NOT the same (or even close) to the MD1 or MD1A as it uses a subminiature tube. I bought one once when MF was blowing them out, thinking that it might match my MD1A. Sent it back.
Given all that, though, I'd strongly consider Mr. Bowes' advice on the matter. You could pick up a used GT, MXL, etc. mic and save and wait to get a really good one. My 2 cents.
