T
travelin travis
why is it bad to power up a tube amp without being connected to a speaker/speaker cab?
VERY SIMPLIFIED EXPLANATIONTravisinFlorida said:why is it bad to power up a tube amp without being connected to a speaker/speaker cab?
boingoman said:The reality is a bit more complex in terms of how V, C, and R interact, as they can affect each other in a tube amp in other ways aside from being static values plugged into a formula, but that is basically the deal.
ggunn said:I'm not challenging you on this, but can you point me to the comprehensive explanation, like a web site or something? I am degreed in EE, so I'm pretty sure I can get it. I have read some tube books (they don't teach tubes in EE any more) and rebuilt a couple of amps, and I don't remember any of the texts mentioning or explaining this effect.
Thanks,
I don't even know what I meant, though I have an idea swimming around. Maybe you've got some input.
)boingoman said:Maybe that was a little clumsily worded.I don't even know what I meant, though I have an idea swimming around. Maybe you've got some input.
So I though it was more important to stick to the main reasons tube amps fail with incorrect loads: too much current with a low load, and too much voltage with a high load.
ggunn said:I'm hip to low resistance/impedance (high load) => high current => component failure, but for a given voltage source, high impedance (low load) => low current. The AC voltage swings inside a tube are small compared to the DC plate voltages, and I don't see why decreasing the load (increasing the resistance) would cause these voltages to become extreme. Your invocation of Ohm where the voltage increases with resistance only holds true if current remains constant, and current rather than voltage is usually determined by resistance.
Anyway, I'd really like to see a concise engineering explanation of this effect. Again, I am not claiming that you are wrong; I'd just like to see the mechanics of how this failure occurrs.
I will find out for sure, but here are some further ponderings.
boingoman said:Thanks for the benefit of the doubt.I will find out for sure, but here are some further ponderings.
What you said about ohm's law is true, but we are talking about a circuit designed to produce power into a specific load.
Making it about power changes a few things. Maybe that's what I meant when I said thing were a little more complex.
With the addition of a specified power, voltage and current have an inverse relationship as the resistance changes.
100W@ 8ohms = 28.3 volts, 3.5 amps
100W@ 16ohms= 40 volts, 2.5 amps
100W@ 1000 ohms= 316 volts, .316 amps
As current goes down due to higher resistance, voltage has to increase to keep the specified power output.
In addition, like you said, the AC voltage swings in the tube are small. But those voltages are determined by the rest of the circuit including the speaker, not the tube itself. The tube has no built-in limits or operating range. It will produce higher voltages or draw more current to make power until it or something else fails. The rest of the circuit, including the speaker, determines the tube's operating range, keeps it safe, and basically lets it produce X amount of output voltage across a specific load and draw Y amount of current to produce Z amount of power for a given input signal.
Putting too high a resistance on the amp affects the whole output circuit, and allows the tube to operate outside the safety limits imposed by the original design, as if the amp is "trying" to put it's rated power into whatever load you throw at it, though it can only do so safely into the load it was designed to handle.
If you put a 100ohm speaker on a 100W amp designed for an 8 ohm load, instead of putting out 28.3 volts and 3.5amps, the tube sees less current flow and puts out a higher voltage. It "thinks" it is still hooked to the correct load, and is "looking" to make a certain amount of power, it seems. It compensates with higher V to make up for less C.
With a 1000ohm load, current flow is down further, and voltage goes even higher.
At some point, either the tubes or the transformer give up the game, and your amp is smoked.
Am I getting closer?![]()
ggunn said:I don't know. If you look at power amp output ratings, they roughly double as resistance halves, so I am not sure that your assumption that your theoretical amplifier puts out 100 watts into whatever load it is presented with is accurate. Also, the voltage output of a tube is limited by its bias voltage; it cannot create energy, it can only gate it. That's why they are referred to as "valves"
I must google some more...
Huuuuhhh?!?boingoman said:I was anthropromorphising a bit.
TravisinFlorida said:Man I gotta learn more about electronics, amps. If only someone would write "Tube Amp Building for Dummies".
