nate_dennis
I can't find anything online about the VX. Can you tell me a little about it?
SCXD does have an all-digital, all-solidstate preamp section, on both channels, which is fed through a 12AX7 into the dual 6V6 power section (yes, i'm just repeating what I read, but it's definitely so).
so it truly is a hybrid, but I like to call it "reverse hybrid" (much better) vs. the hybrids with a preamp tube and a solid-state power section.
as such it sounds pretty good. it really does shine after some minimal upgrades, especially the speaker. a combo amp is 2 things in one - amplifier and speaker cab, so the cheap ones are often a decent amp (with bad tubes in need of a replacement) with a cheap speaker. judge them separately.
So why dont you try the Vox AD50VT then for $350?
I love old Gibson amps. Some of them are overlooked gems depending on the tone you're after. If you liked the skylark you would love the Explorer or Minuteman. Cathode biased EL84s with great reverb and tremolo. They get sweet and creamy at reasonable volume. I've been using a Minuteman as my go to amp for several years. It was well within your price range. I got it off e-bay. If you want a ton of crunch it's probably not a good choice, but it crunches enough for me.
Another great choice would be a '60s vintage Ampeg ReverbRocket or Gemini II. SWEET and reasonably priced. You might have to go $425 or so for one of those.
Well, that's not a tube amp. And while I'm no stickler for tubes, the OP did ask for tube amp suggestions.
And then later said he's going to run a modeller or some kind of multi fx unit thru it...... in that case, the Vox is a good compromise at that price range. If one is running a modeller/fx unit thru it then it doesn't seem to matter much after that if it's "all tube".....![]()
Thanks so much for all of the input. I'm really leaning toward the Peavey Delta Blues. There are a few on ebay with good prices. Have any of you recorded one? How do they do in the studio? Thanks.
Hey Hungover,
I tried to leave you some rep but my dog hit the send button before I got anything typed in.
I've got a gemini II as well but it's not working right now. You only thought you loved your Telecaster until you plug it into one of those. I also have an Ampeg M-15 (an obese Mercury) Best use of 6L6s I ever heard.
OK We can be friends.
My animals do that too, especially the cat... there's 2 common reasons that your lovely checkerboard friend is currently ailing. 1. stick mr. meter on the output transformer, it might be shorted, it was more common on the G-12 but it happens on the big brother. 2. The filter caps are tired after 50 years. That was the culprit on mine. I usually play my electric 12s out of it. I bet that thing kills with a tele though. I've got a Firebird VII that works wonderfully. Does yours have the Jensen 15 or something more exotic? I've been thinking about swapping the speaker.
