A
Adam P
As I mentioned before in the "Recording Screaming" thread, I'm going to be recording some friends in a few weeks. I'd like to use two mics on the snare, one on top and one doing the "LDC close to the floor" approach that I've read about here. I like that the bottom snare mic adds a lot to the sound with the way it picks up the sound of the snares quite well.
I plan to use two mics on the kick drum as well, and because the LDC by the floor picks up quite a bit of kick itself, I'd prefer to gate it out if possible. The guys I'm recording have a Behringer Composer Pro MDX2200 dual-channel compressor with a noise gate. I'd like to use the side channel of the compressor to trigger the bottom snare mic's signal, using the top mic as the trigger source. I know that the Behringer is not the highest quality piece of gear, but I'm a believer in working with what you've got to the best of its potential. I'm not sure how to go about hooking this up to trigger, however. I think that I should run the signal out from the top snare's preamp into the sidechain input on the compressor, and then run the sidechain output to my Layla input. I would then run the preamp output for the bottom snare mic into the compressor's primary input, and run the compressor's output into another input on the Layla. I would then adjust the gate until it was letting through the proper amount of signal.
Can anyone tell me if this would be the right way to hook this up? If not, how should I go about doing this?
Thanks.
Edit: If I wanted to bus the two snare tracks to a single track, would I want to run the Snare top's insert I/O into the sidechain I/O on the compressor, and the Snare bottom's insert I/O into the primary I/O on the compressor?
Thanks.
